audiofreak Posted 10 november 2007 Report Share Posted 10 november 2007 .... Link to comment Share on other sites More sharing options...
Guest Kraus vonBentinck Posted 10 november 2007 Report Share Posted 10 november 2007 1,8 meter was "men" destijds op uitgekomen Lees dit maar weer eens door. Over het nut ervan mag ieder het zijne weer eens denken. Dat is het verstandigste bij alle kabel-issues Link to comment Share on other sites More sharing options...
RobT Posted 10 november 2007 Report Share Posted 10 november 2007 Caelin Gabriel Shunyata Research Inc.: >>.......A power cable on the other hand is not transmitting a signal. It is conducting A.C. power and its sonic superiority will be determined by its ability to deliver current (steady-state and instantaneous) and its ability to deal with the EMI effects of the components to which it is attached. SInce a power cord is composed of a hot and neutral wire that the component sits between, a change in the length of the cord will increase the size of the "buffer" around the component. In the specific case of PowerSnakes - we use a proprietary substance within our cables that absorbs EMI. Increasing the length of the cable, increases the coupling effect to this substance, therefore increasing the performance of the cable. --- In general, I would not recommend a power cord that is shorter than 3 feet or 1 meter in length. ........<< Meer hierover: Why shorter is not better http://db.audioasylum.com/cgi/m.mpl?forum=cables&n=7311 Audiogonner en kabelboer Michael Wolff van Wolff Audio post op Audiogon: >>Longer Power Cords Sound better? No doubt, it is a known fact that the higher frequencies are shorter wave length electrons and therefore cannot travel as far as the midrange electrons. Just like spermatazoa. That's why the longer power cords have more midrange.<< Link to comment Share on other sites More sharing options...
Pjotr Posted 10 november 2007 Report Share Posted 10 november 2007 Het lijkt mij dat een netsnoer lang genoeg moet zijn om fatsoenlijk in een stekkerblok of wandcontactdoos te kunnen passen Zit je al gauw op meer dan een meter. Dus wat is het probleem? Btw, als ik de redenatie van Adiogonner even doorzet en de lengte in de muur en naar de centrale mee reken zou er uit mijn set alleen nog subsonisch geluid kunnen komen. Dat is niet het geval. Link to comment Share on other sites More sharing options...
Hans van Liempd Posted 10 november 2007 Report Share Posted 10 november 2007 Dank je Kraus. Het gaat dus om o.a. instraling van GSM en de golflengte hiervan enz begrijp ik eruit. Ook las ik iets over de broer van Hans (Chris) hierover, maar alleen staat die reactie of uitlegging niet in dit topic. Maar waar dan wel ? Hans ???? groet, Die heeft volgens mij hier helemaal nog nooit wat geschreven... Ik heb lange en korte gevlochten kabels. Wanneer ik ze omwissel hoor ik geen verschil... Ik denk dus... hoe korter hoe beter. Net zoals voor alle andere bekabeling. Link to comment Share on other sites More sharing options...
ezo Posted 10 november 2007 Report Share Posted 10 november 2007 hoi wat mij betreft hoe korter hoe beter maar veel zal het niet uit maken gr e Link to comment Share on other sites More sharing options...
erik klijnsmit Posted 10 november 2007 Report Share Posted 10 november 2007 hoi wat mij betreft hoe korter hoe beter maar veel zal het niet uit maken gr e inderdaad, je kunt beter een netsnoer nemen van 1 meter dan van 2 meter, die van 1 meter heeft 50% minder weerstand!! ps; of een installatie last heeft van storing is heel makkelijk te controleren: zet een cd op met een stille passage (een track zonder geluid) zet de volumeknop op stevig luisterniveau. ga luisteren..... druk op pauze.... hoor je verschil dan heeft je set last van storing. blijft het even stil, dan heb je geen last. Link to comment Share on other sites More sharing options...
