Robbert Posted 9 januari 2008 Report Share Posted 9 januari 2008 Wie heeft hem al gehoord? Link to comment Share on other sites More sharing options...
Guest Rein! Posted 9 januari 2008 Report Share Posted 9 januari 2008 Klinkt mooi warm en transparant. Link to comment Share on other sites More sharing options...
Robbert Posted 9 januari 2008 Author Report Share Posted 9 januari 2008 Is er een klankverschil met de "oude" unico versterker die 2 x 80 w. had? Link to comment Share on other sites More sharing options...
fmjwillems Posted 9 januari 2008 Report Share Posted 9 januari 2008 Robbert said: Is er een klankverschil met de "oude" unico versterker die 2 x 80 w. had? Nee Link to comment Share on other sites More sharing options...
Guest Rein! Posted 9 januari 2008 Report Share Posted 9 januari 2008 Robbert said: Is er een klankverschil met de "oude" unico versterker die 2 x 80 w. had? Nee Link to comment Share on other sites More sharing options...
joopie Posted 9 januari 2008 Report Share Posted 9 januari 2008 wat een sukkel. Link to comment Share on other sites More sharing options...
fmjwillems Posted 9 januari 2008 Report Share Posted 9 januari 2008 joopie said: wat een sukkel. Mee eens. Link to comment Share on other sites More sharing options...
Robbert Posted 9 januari 2008 Author Report Share Posted 9 januari 2008 Unison Unico Secondo Review This Italian beauty is a real hidden gem t's a big amp and a well-filled case Very good detail and coherence Precise and deep imaging Verdict Unison may not be shouting about it, but this amp is very good at retrieval of details and also at placing them in their appropriate context Hi-fi companies are a funny lot. As the Unico Secondo's maker demonstrates, they can produce a nice new amp... and forget to put it on their website, surely most people's first port of call for information these days. Luckily, Unison Research's UK distributor is more alert, and from it we learn that this is the "second generation" of the Unico, a well-established valve/transistor hybrid design from Italy. Not for the first time, we find ourselves wondering just how much 'valve character' one really gets from one double triode small-signal valve per channel, but, well, we've had good results from Unico models in the past... It's a big amp and a well-filled case. The mains transformer actually looks quite small at first, but only because it's dwarfed by the case itself and the heat sink next to (and cunningly profiled around) it. AdvertisementMoving across the case to the left, one finds a large rectifier and the usual reservoir capacitors, plus two pairs of MOSFET output devices per channel. Most of the audio amplification is done on a large board which carries the audio circuits (the valves and some ICs, a couple with their numbers intriguingly scratched off). A daughterboard at the rear bears the selector switch, a mechanical type not accessible via the remote control, plus the input circuit for the single balanced input. The remaining five inputs are line-level unbalanced - one is upgradeable to phono operation. Twin speaker terminals are fitted, plus phono outputs marked 'Monitor' (aka tape out) and 'Subwoofer' (pre out). We were particularly taken with the look of this model, with its extra-thick front panel - very aspirational! It's a bit horses for courses, as ever, but this was clearly one of the hits of the day. One listener never quite found the levels of excitement he got elsewhere, for instance, but the others had little but good to say about it. Most of all, they found in it the punch and immediacy thought lacking with some other contenders. Obviously, the Michael Jackson track benefited from this considerably, but it wasn't the only one to enjoy new-found life. Some interesting direct comparisons were made with the RA combo (remember our panel were listening blind), the consensus being that this was probably the more neutral of the two contenders, but perhaps (as a consequence?) less upfront. The Unico seemed to have more 'boogie factor' and perhaps slightly more impression of depth - and even, one listener suggested, height - in stereo images. It also seemed to have very impressive 'blackness' between notes, and some great dynamics too, not just in terms of swing from maximum to minimum, but also in the naturalness with which that was achieved. Occasionally such qualities are achieved at the expense of analysis - not here. In fact, the Unico was superbly detailed, making clear the varied tones and directions of the instruments within the whole, but never separating them unnaturally. If anything, sounds became more solid and real as they got more complex, with highly stable image placement and some very good depth too. And tonality? Well, given that not one listener mentioned the subject with any of the tracks, there can't be much wrong there! Hi-Fi Choice Link to comment Share on other sites More sharing options...
buizenbart Posted 9 januari 2008 Report Share Posted 9 januari 2008 Wat wil je nou eigenlijk, Robbert? Link to comment Share on other sites More sharing options...
Robbert Posted 9 januari 2008 Author Report Share Posted 9 januari 2008 Ik kan deze versterker binnenkort thuis beluisteren. Zoek een andere versterker. Komend weekend kan ik thuis de Marantz 15S1 set beluisteren. Ik heb al een Luxman 505F versterker thuis gehad. Wonderschone versterker, maar kost wel 3000,--. Daarom eerst nog eens naar de andere luisteren. Link to comment Share on other sites More sharing options...
fmjwillems Posted 9 januari 2008 Report Share Posted 9 januari 2008 buizenbart said: Wat wil je nou eigenlijk, Robbert? Dat weet hij zelf ook niet. Link to comment Share on other sites More sharing options...
Robbert Posted 10 januari 2008 Author Report Share Posted 10 januari 2008 Keuze is gemaakt. Topic kan gesloten worden. By the way; bejegening op buitenlandse forums is heel wat fatsoenlijker. Versterkt mijn mening dat Nederlanders geen fatsoen kennen. En dat is tevens 1 van de redenen dat ondergetekende naar Duitsland vertrekt! Link to comment Share on other sites More sharing options...
joopie Posted 10 januari 2008 Report Share Posted 10 januari 2008 ook in duitsland ga je weggejaagd worden : Link to comment Share on other sites More sharing options...
Robbert Posted 10 januari 2008 Author Report Share Posted 10 januari 2008 Nee; het is terecht "Deutschland Link to comment Share on other sites More sharing options...
mordante Posted 10 januari 2008 Report Share Posted 10 januari 2008 Waarom kunnen mensen niet gewoon reageren op een vraag? Als je niks te melden hebt over het onderwerp hou dan je mond. Link to comment Share on other sites More sharing options...
Guest Rein! Posted 10 januari 2008 Report Share Posted 10 januari 2008 Vind ik ook Mordante. Link to comment Share on other sites More sharing options...
olivetti Posted 10 januari 2008 Report Share Posted 10 januari 2008 Robbert krijgt op een normale vraag inderdaad een erg eigenaardig antwoord. Link to comment Share on other sites More sharing options...
mordante Posted 10 januari 2008 Report Share Posted 10 januari 2008 olivetti said: Robbert krijgt op een normale vraag inderdaad een erg eigenaardig antwoord. klopt. Link to comment Share on other sites More sharing options...
buizenbart Posted 10 januari 2008 Report Share Posted 10 januari 2008 Robbert stelt zich misschien nogal hulpeloos op en weet niet waar hij moet beginnen, maar om dan meteen in de derde persoon over "wat een sukkel" te gaan praten, de meeste mensen hear zijn juist behulpzaam, ik vind het onterecht om zo iemand meteen te gaan afbranden, en als je dan ook nog gaat suggereren dat hij hulp nodig heeft vind ik grof en onfatsoenlijk.. Link to comment Share on other sites More sharing options...
kappa7 Posted 10 januari 2008 Report Share Posted 10 januari 2008 buizenbart said: Robbert stelt zich misschien nogal hulpeloos op en weet niet waar hij moet beginnen, maar om dan meteen in de derde persoon over "wat een sukkel" te gaan praten, de meeste mensen hear zijn juist behulpzaam, ik vind het onterecht om zo iemand meteen te gaan afbranden, en als je dan ook nog gaat suggereren dat hij hulp nodig heeft vind ik grof en onfatsoenlijk.. Wil ik mij graag bij aan sluiten. Groetjes George. Link to comment Share on other sites More sharing options...
Guest Rein! Posted 10 januari 2008 Report Share Posted 10 januari 2008 Onfatsoenlijke mensen zijn het... Link to comment Share on other sites More sharing options...
spido Posted 11 januari 2008 Report Share Posted 11 januari 2008 Gooi ons alsjeblieft niet allen op Link to comment Share on other sites More sharing options...
azh Posted 11 januari 2008 Report Share Posted 11 januari 2008 Dank je, Mordante. Welke is het geworden Robbert, en waarom? Link to comment Share on other sites More sharing options...
joopie Posted 11 januari 2008 Report Share Posted 11 januari 2008 is richting duitsland Link to comment Share on other sites More sharing options...
olivetti Posted 11 januari 2008 Report Share Posted 11 januari 2008 joopie said: is richting duitsland Je zou ook kunnen reageren op wat een aantal mensen vond van jouw reaktie. Wellicht zinniger. Link to comment Share on other sites More sharing options...
