Pjotr Posted 30 augustus 2010 Report Share Posted 30 augustus 2010 Oud of nieuw... wat is beter? Deze firma, gespecialiseerd in het opkalefateren van luidsprekers, lijkt het antwoord te weten: (...) Did you know that most older speakers are built much better and are higher quality than new speakers today? As a rule of thumb, speakers double in price about every 10 years. What this means is the speakers you bought in 1980 for $200-$400 would now cost about $800-$1600 to replace with equal quality today. (...) One of the easiest ways to do this is to lift the speakers to see how heavy they are. Odds are, the new speakers will probably weigh less than half what your old speakers weigh. This is because the quality of the parts used in older speakers were much better. Therefore, they are heavier. The cabinetry itself is also usually much better quality (real wood vs. plastic). Even if you could buy new speakers for only $350 you would still save about 80% by repairing your current speakers instead. What a deal! Many people have been brainwashed by salesmen into thinking their current speakers just won't sound as good as new speakers. Don't believe the hype! This is just not true. After we repair your speakers, they will sound exactly like they did when they were brand new, and better than most new speakers you can buy today. You know better than anyone how great your speakers sounded when they were new. Don't let a bunch of salesmen trick you into buying inferior speakers! Speaker technology has not changed much in the past 40 years. There have been minor advancements in power handling. But hey, you probably didn't over power your speakers anyway. They probably just need the foam edges replaced on the woofers. And if they do need reconing we can upgrade the power capacity if you'd like. (...) http://www.speakerrepair.com/OCSyes.html Tja, zou ik ook adverteren als mijn broodwinning het opkalefateren van oude meuk zou zijn. Er wordt nogal de nadruk gelegd op diverse (conus)materialen in dit draadje maar wat er ook gebruikt wordt, een speaker valt of staat met het filterontwerp. Link to comment Share on other sites More sharing options...
Seed7 Posted 30 augustus 2010 Report Share Posted 30 augustus 2010 [...] maar wat er ook gebruikt wordt, een speaker valt of staat met het filterontwerp. Hoe kom je daar nou weer bij Pjotr, alles anders dan een eerste orde filter is toch vloeken in de kerk ... Link to comment Share on other sites More sharing options...
Pjotr Posted 30 augustus 2010 Report Share Posted 30 augustus 2010 [...] maar wat er ook gebruikt wordt, een speaker valt of staat met het filterontwerp. Hoe kom je daar nou weer bij Pjotr, alles anders dan een eerste orde filter is toch vloeken in de kerk ... Oh ja, dat waar ook, plemp er een spoel en een condensator in en het zit wel goed Ben toch menig Pioneer, Akai, Sonie enz. spaanplaat kissie van weleer tegengekomen waar dat zo zat. Doe toch maar niet voor mij... Link to comment Share on other sites More sharing options...
Nautilus Posted 30 augustus 2010 Report Share Posted 30 augustus 2010 Voor mij is de combinatie van versterker met LS erg belangrijk. Ik heb nog steeds ontzettend veel plezier van mijn ouder B&W Matrix 802 serie II LS, een aantal jaren geleden 2de hands gekocht voor 1500 Link to comment Share on other sites More sharing options...
Richard 2 Posted 30 augustus 2010 Report Share Posted 30 augustus 2010 XBL (pdf) en niet alleen voor subwoofers, de eerste midlaag units zijn al op de markt.Op de omgekeerde oplossing heeft Manger het patent. Bij de XBL is de luchtspleet gesplitst en een lange spreekspoel, bij de manger is de spreekspoel gesplitst in een lange luchtspleet. Voordeel van de Manger-oplossing is dat de spreekspoel veel lichter kan worden uitgevoerd wat de midden- en hogetonenweergave ten goede komt. Link to comment Share on other sites More sharing options...
WanFie Posted 30 augustus 2010 Author Report Share Posted 30 augustus 2010 Voor mij is de combinatie van versterker met LS erg belangrijk. Ik heb nog steeds ontzettend veel plezier van mijn ouder B&W Matrix 802 serie II LS, een aantal jaren geleden 2de hands gekocht voor 1500 Link to comment Share on other sites More sharing options...
m44 Posted 30 augustus 2010 Report Share Posted 30 augustus 2010 Voor mij is de combinatie van versterker met LS erg belangrijk. Ik heb nog steeds ontzettend veel plezier van mijn ouder B&W Matrix 802 serie II LS, een aantal jaren geleden 2de hands gekocht voor 1500 Link to comment Share on other sites More sharing options...
spido Posted 30 augustus 2010 Report Share Posted 30 augustus 2010 (...) Er wordt nogal de nadruk gelegd op diverse (conus)materialen in dit draadje maar wat er ook gebruikt wordt, een speaker valt of staat met het filterontwerp. (...) Hoe beroerder de units, en hoe meer de behuizing na-ijlt. des te ingewikkelder het filter moet zijn... Een filter is een noodzakelijk kwaad: vooral wanneer er veel moet worden verdoezeld. Ingewikkelde filters (hogere orde, met correctienetwerken) tasten de impulsverwerking aan en bederven de fasekarakteristiek. Echter: Hoe beter de units, en hoe minder resonant de "kast", des te eenvoudiger kan het filter zijn! Betere impulsverwerking, betere fasecoherentie. Hiep hiep hoera voor goede units in combinatie met eenvoudige (liefst eerste orde) filters en (vrijwel) onvervormbare (spekstenen) pomphuizen! It took a long way... via BBC monitors, Rogers. Harbeth, "piston action" Leak, Cooke, "floppy" Briggs, transmission lines (Bailey), filler lines (Baekgaerd c.s.) and anything promising to get there... But now I KNOW! (I think...) Link to comment Share on other sites More sharing options...
Guest Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Spidon je hebt het fase domein en het tijds domein en als je het samenvoeg is het gelukkig niet perfect. Link to comment Share on other sites More sharing options...
Pjotr Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Spidon je hebt het fase domein en het tijds domein en als je het samenvoeg is het gelukkig niet perfect. Ja logisch, dat is pas het begin. Er moet ook nog een snufje frequentie domein en een blokje blokgolf bij. Dan heb je een goede basissoep. daar wat brokken speksteen bij en een Kevlar conus, weekje laten pruttelen, moet jij eens zien hoe Perfect het wordt Link to comment Share on other sites More sharing options...
Guest tubejack Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 [......] Een filter is een noodzakelijk kwaad Beste Spido, Gezien de reacties, is je bericht aan "dovemansoren" gericht. Als bezitter van een stel PP's is mijn mening natuurlijk verre van objectief. Maar e.e.a. past ook 100% in mijn filosofie, m.b.o. een zo natuurlijk mogelijke geluidsweergave. Een oplettende lezer weet, dat er wel meer luidsprekerfabrikanten zijn/waren die 1e orde filters gebruiken.... Mijn vorige Translator Impact 50 hadden ook fase lineaire filters en ook de Hepta Menhir's waar ik daarvoor mee speelde .... Bij de Link to comment Share on other sites More sharing options...
Pjotr Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Pas je wel op Jack dat je Spido niet met iemand anders verwart? Dat filter mag dan elektrisch wel eerste orde zijn, akoestisch en dat is waar het om gaat, kom je altijd hoger uit: 3e orde. Waarmee ik niet wil zeggen dat zo'n filter niet fraai zou zijn maar het blijft een theoretische exercitie en niet enig zaligmakend. Link to comment Share on other sites More sharing options...
Phelsuma Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Wat een kul. Inderdaad zijn heel veel van die moderne zgn. "high end" luidsprekers niet om aan te horen van de scherpte. Ja, je hoort alle pingeltjes zo goed........ Dat kan/zal dan allemaal best hifi of neutraal zijn, als je er koppijn van krijgt is het doel, nl. muziekgenieten, niet echt bereikt. Ik onderschijf jouw mening volkomen. Ik heb in de loop van de jaren heel wat versterkers en luispreker combi's gehad: van Sphinx met JMR Offrande tot Audio Research met Avalon Opus Ceramique. Geen van die combi's gaf mij meer voldoening dan de huidige combi van een setje 30 jaar oude Sansui CA-3000/BA-5000 op mijn huidige Apogee Duetta Sign. uit 1992. Link to comment Share on other sites More sharing options...
Audiopaul Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Wat een kul. Inderdaad zijn heel veel van die moderne zgn. "high end" luidsprekers niet om aan te horen van de scherpte. Ja, je hoort alle pingeltjes zo goed........ Dat kan/zal dan allemaal best hifi of neutraal zijn, als je er koppijn van krijgt is het doel, nl. muziekgenieten, niet echt bereikt. Ik onderschijf jouw mening volkomen. Ik heb in de loop van de jaren heel wat versterkers en luispreker combi's gehad: van Sphinx met JMR Offrande tot Audio Research met Avalon Opus Ceramique. Geen van die combi's gaf mij meer voldoening dan de huidige combi van een setje 30 jaar oude Sansui CA-3000/BA-5000 op mijn huidige Apogee Duetta Sign. uit 1992. Leuk Johan, en die JMR's vond ik >> destijds << (en nu nog steeds) toch hele mooie speakers. Misschien wordt het weer eens tijd voor een nieuw bezoekje? Link to comment Share on other sites More sharing options...
Phelsuma Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Wat een kul. Inderdaad zijn heel veel van die moderne zgn. "high end" luidsprekers niet om aan te horen van de scherpte. Ja, je hoort alle pingeltjes zo goed........ Dat kan/zal dan allemaal best hifi of neutraal zijn, als je er koppijn van krijgt is het doel, nl. muziekgenieten, niet echt bereikt. Ik onderschijf jouw mening volkomen. Ik heb in de loop van de jaren heel wat versterkers en luispreker combi's gehad: van Sphinx met JMR Offrande tot Audio Research met Avalon Opus Ceramique. Geen van die combi's gaf mij meer voldoening dan de huidige combi van een setje 30 jaar oude Sansui CA-3000/BA-5000 op mijn huidige Apogee Duetta Sign. uit 1992. Leuk Johan, en die JMR's vond ik >> destijds << (en nu nog steeds) toch hele mooie speakers. Misschien wordt het weer eens tijd voor een nieuw bezoekje? Hoi Paul, Goed weer wat van je te horen. Als je in de buurt van A'dam bent ben je natuurlijk uiterst welkom. De chinees hier is nog steeds uitmuntend. Link to comment Share on other sites More sharing options...
Guest tubejack Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Pas je wel op Jack dat je Spido niet met iemand anders verwart? Dat filter mag dan elektrisch wel eerste orde zijn, akoestisch en dat is waar het om gaat, kom je altijd hoger uit: 3e orde. Waarmee ik niet wil zeggen dat zo'n filter niet fraai zou zijn maar het blijft een theoretische exercitie en niet enig zaligmakend. Ik heb voor het laag en midden g Link to comment Share on other sites More sharing options...
Guest KT88 Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Ik onderschijf jouw mening volkomen. Ik heb in de loop van de jaren heel wat versterkers en luispreker combi's gehad: van Sphinx met JMR Offrande tot Audio Research met Avalon Opus Ceramique. Geen van die combi's gaf mij meer voldoening dan de huidige combi van een setje 30 jaar oude Sansui CA-3000/BA-5000 op mijn huidige Apogee Duetta Sign. uit 1992. Da's inderdaad wel een heul fraai setje Johan! Voorversterker nog steeds naar wens? Link to comment Share on other sites More sharing options...
spido Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Oud of nieuw... wat is beter? Deze firma, gespecialiseerd in het opkalefateren van luidsprekers, lijkt het antwoord te weten: (...) Did you know that most older speakers are built much better and are higher quality than new speakers today? As a rule of thumb, speakers double in price about every 10 years. What this means is the speakers you bought in 1980 for $200-$400 would now cost about $800-$1600 to replace with equal quality today. (...) One of the easiest ways to do this is to lift the speakers to see how heavy they are. Odds are, the new speakers will probably weigh less than half what your old speakers weigh. This is because the quality of the parts used in older speakers were much better. Therefore, they are heavier. The cabinetry itself is also usually much better quality (real wood vs. plastic). Even if you could buy new speakers for only $350 you would still save about 80% by repairing your current speakers instead. What a deal! Many people have been brainwashed by salesmen into thinking their current speakers just won't sound as good as new speakers. Don't believe the hype! This is just not true. After we repair your speakers, they will sound exactly like they did when they were brand new, and better than most new speakers you can buy today. You know better than anyone how great your speakers sounded when they were new. Don't let a bunch of salesmen trick you into buying inferior speakers! Speaker technology has not changed much in the past 40 years. There have been minor advancements in power handling. But hey, you probably didn't over power your speakers anyway. They probably just need the foam edges replaced on the woofers. And if they do need reconing we can upgrade the power capacity if you'd like. (...) http://www.speakerrepair.com/OCSyes.html Tja, zou ik ook adverteren als mijn broodwinning het opkalefateren van oude meuk zou zijn. Zou je toch eerst een béétje verstand van luidsprekers moeten zien te krijgen... ("Moeten zien te krijgen... Ik sta te kijken van m'n eigen!") Link to comment Share on other sites More sharing options...
Pjotr Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Zou je toch eerst een b Link to comment Share on other sites More sharing options...
Phelsuma Posted 31 augustus 2010 Report Share Posted 31 augustus 2010 Ik onderschijf jouw mening volkomen. Ik heb in de loop van de jaren heel wat versterkers en luispreker combi's gehad: van Sphinx met JMR Offrande tot Audio Research met Avalon Opus Ceramique. Geen van die combi's gaf mij meer voldoening dan de huidige combi van een setje 30 jaar oude Sansui CA-3000/BA-5000 op mijn huidige Apogee Duetta Sign. uit 1992. Da's inderdaad wel een heul fraai setje Johan! Voorversterker nog steeds naar wens? Hoi Sander, de voorversterker presteert nog steeds naar behoren. Het is tijd dat je de eindversterker ook eens onderhanden neemt. Maar maak ik nog wel een afspraak daarvoor. Johan Link to comment Share on other sites More sharing options...
Andre Kel Posted 25 september 2010 Report Share Posted 25 september 2010 Hans, wat heb je gekocht dan? Daar ben ik dan wel weer benieuwd naar. Tja en wat is beter, ik luister al 11jaar met heeel veel plezier naar mijn B&W Matrix 801 mk3. En ja als ik dan ergens ben en ik hoor de 800D (de nieuwe heb ik nog niet gehoord) dan denk ik HEBBEN! Maar hoe klinken ze bij mij...? Is die bas net zo lekker lag als bij de matrixen op een heel laag geluidsniveau? Ja het is meer helder en meer gedetaileerd. Ook mooier vind ik dan. Maarja heb ik een sleuf in mijn rug waar ik geld in stop? Nee. Dus ik ben nog steeds blij met mijn wapper en flapper techniek bas uit de jaren negentig. Maar lekker klinken doet het voor mij. Voor mij, en aangezien ik voor mij de belangrijkste persoon op aarde ben... is de keuze makkelijk gemaakt. Voor mij, hahahaha Kortom, als je nieuw beter vind en je bent tevreden, proficiat. Vind je oud beter en ben je tevreden, proficiat. Is het een Sony, proficiat. Ben je blij, proficiat.... Maar eeh Hans, wel even zeggen wat je gekocht hebt... Kan ook zijn dat ik het gemist heb, Groet, Andre Link to comment Share on other sites More sharing options...
WanFie Posted 26 september 2010 Author Report Share Posted 26 september 2010 Hans, wat heb je gekocht dan? Daar ben ik dan wel weer benieuwd naar. Tja en wat is beter, ik luister al 11jaar met heeel veel plezier naar mijn B&W Matrix 801 mk3. En ja als ik dan ergens ben en ik hoor de 800D (de nieuwe heb ik nog niet gehoord) dan denk ik HEBBEN! Maar hoe klinken ze bij mij...? Is die bas net zo lekker lag als bij de matrixen op een heel laag geluidsniveau? Ja het is meer helder en meer gedetaileerd. Ook mooier vind ik dan. Maarja heb ik een sleuf in mijn rug waar ik geld in stop? Nee. Dus ik ben nog steeds blij met mijn wapper en flapper techniek bas uit de jaren negentig. Maar lekker klinken doet het voor mij. Voor mij, en aangezien ik voor mij de belangrijkste persoon op aarde ben... is de keuze makkelijk gemaakt. Voor mij, hahahaha Kortom, als je nieuw beter vind en je bent tevreden, proficiat. Vind je oud beter en ben je tevreden, proficiat. Is het een Sony, proficiat. Ben je blij, proficiat.... Maar eeh Hans, wel even zeggen wat je gekocht hebt... Kan ook zijn dat ik het gemist heb, Groet, Andre LINK hier is het hele verhaal te lezen... Link to comment Share on other sites More sharing options...
mumsoft Posted 26 september 2010 Report Share Posted 26 september 2010 Misschien dat velen oud fijn vinden, wat mij betreft gaat dat alleen op voor draaitafels. Verder heb ik alles nieuw. - De versterker, want ook nu worden er prachtige gebouwd, waarvan de LFD er zeker een is. Zou ik anders moeten kiezen, zou ik het zoeken bij Nelson Pass. - De streamer, tja, dat kan ook niet anders. Is d Link to comment Share on other sites More sharing options...
Ruud Posted 26 september 2010 Report Share Posted 26 september 2010 - Last but not least: gehakt. Zonder die supernieuwe tweak (gebaseerd op oude kennis) zou het nu niet zo fabelachtig mooi klinken bij mij. Is een revolutie in audio. M rc Hoewel ik niet tegen datgene bent wat jij bedoelt geef je er wat mij betreft teveel gewicht aan. Link to comment Share on other sites More sharing options...
m44 Posted 26 september 2010 Report Share Posted 26 september 2010 teveel gewicht? nobelprijs zeg ik je Link to comment Share on other sites More sharing options...
