WanFie Posted 12 februari 2013 Report Share Posted 12 februari 2013 http://www.ecdesigns.nl/sd-player/sd2 Heeft iets bijzonders. Kennelijk heeft het voordelen. En van binnen. Ook in onderdelen te koop. Helaas opamps in de uitgangstrap. Volgende week mag ik deze beluisteren. Link to comment Share on other sites More sharing options...
Ivan10 Posted 12 februari 2013 Report Share Posted 12 februari 2013 Is het een harde schijf met DAC?| Quote SD player 1541A-MK4 The SD-player is a novel 44.1 / 16 digital audio source with integrated TDA1541A-MK4 DAC. Music (wav) is stored on solid-state memory cards supporting up to 99 CDs and 99 tracks / CD and random play. SD(HC) memory cards up to 32Gb are already tested and supported, these offer storage for up to 56 CD images. Free ECDSD utility program for Linux, Mac OSX and Windows is available for easy memory card programming. Disc and Track numbers appear on large, very easy to read LED displays. SD-player can be controlled by 6 front panel keys or by IR remote control. The unit comes with a low cost universal RC, the High-End RC is optional. Optional battery power supply eliminates mains interference. The SD-player has single-ended outputs (RCA), 500 Ohms output impedance and 0.7V rms (2Vpp) output amplitude. Recommended minimum load (volume potentiometer) equals 10 K Ohms. SD-player passive output circuit offers maximum resolution, yet requires careful matching with connected equipment for optimal results. Recommended volume control, 10K wire wound potentiometer. Recommended power amplifiers, linear MOSFET or tube amplifiers with fewest possible semiconductors or tubes in the signal path. The use of digital power amplifiers is not recommended. Link to comment Share on other sites More sharing options...
WanFie Posted 12 februari 2013 Author Report Share Posted 12 februari 2013 Neeeeeee.... alleen SD kaartjes. Geen loopwerk, geen koeling, nauwelijks electronica, batterij gebruik mogelijk (optie). Link to comment Share on other sites More sharing options...
Karma Posted 13 februari 2013 Report Share Posted 13 februari 2013 On 12-2-2013 at 19:16, Hans van Liempd said: Neeeeeee.... alleen SD kaartjes. Geen loopwerk, geen koeling, nauwelijks electronica, batterij gebruik mogelijk (optie). Ik ben wel benieuwd waarom ze een TDA 1541A gebruikt hebben als converter. Het is beslist een muzikaal klinkende chip, maar is afkomstig uit de eind jaren tachtig. Link to comment Share on other sites More sharing options...
Guest tubejack Posted 13 februari 2013 Report Share Posted 13 februari 2013 Waarschijnlijk voor het geluid en de mogelijkheid van non-oversampeling. Quote Recommended power amplifiers, linear MOSFET or tube amplifiers with fewest possible semiconductors or tubes in the signal path. The use of digital power amplifiers is not recommended. Niet geschikt voor Array Link to comment Share on other sites More sharing options...
WanFie Posted 13 februari 2013 Author Report Share Posted 13 februari 2013 Wat is een digitalpoweramp...?? Een Array in ieder geval niet. Dat is klasse aB met een heel kleine a. Klasse D is ook niet digitaal. En die DAC... volgens mij zit er in mijn PinkFaun DAC ook zo'n ding. Klinkt fantastisch. Link to comment Share on other sites More sharing options...
r.a.v.o.n Posted 13 februari 2013 Report Share Posted 13 februari 2013 Sinds wanneer bestaan er digitale audioversterkers? En waarom zou er geen TDA 1541A uit de jaren tachtig in mogen? Had het een ruisbuisschakeling uit de jaren vijftig moeten zijn? En waarom SD kaartjes? Is een SSD niet aantrekkelijker? Link to comment Share on other sites More sharing options...
Duck-Twacy Posted 13 februari 2013 Report Share Posted 13 februari 2013 NAD heeft er 2. http://thehbproject.com/nl/testen/118/NAD-C-390DD-digitale-versterker Nog meer rariteiten: http://www.6moons.com/audioreviews/xxhighend/1.html Excl usb stick. Link to comment Share on other sites More sharing options...
r.a.v.o.n Posted 13 februari 2013 Report Share Posted 13 februari 2013 On 13-2-2013 at 21:10, Duck-Twacy said: NAD heeft er 2. Ah, ze bestaan. Dankjewel. Link to comment Share on other sites More sharing options...
WanFie Posted 13 februari 2013 Author Report Share Posted 13 februari 2013 On 13-2-2013 at 18:59, r.a.v.o.n said: En waarom SD kaartjes? Is een SSD niet aantrekkelijker? Een SD kaart heeft kennelijk zeer weinig electronica aan boord. Link to comment Share on other sites More sharing options...
carl Posted 14 februari 2013 Report Share Posted 14 februari 2013 Ik snap niet helemaal hoe het werkt als je geen loopwerk gebruikt. Link to comment Share on other sites More sharing options...
mumsoft Posted 14 februari 2013 Report Share Posted 14 februari 2013 Gewoon wat bestandjes van zo'n kaartje afplukken. Die kunnen net zo goed van een floppy of harde schijf komen. Het is een vorm van streaming. Link to comment Share on other sites More sharing options...
Karma Posted 21 februari 2013 Report Share Posted 21 februari 2013 En hoe is deze bevallen qua geluid? Link to comment Share on other sites More sharing options...
WanFie Posted 22 februari 2013 Author Report Share Posted 22 februari 2013 Wat opviel, was het extreem schone geluid. Stemmen, violen en orgels... het klonk allemaal erg natuurlijk. En dan te bedenken dat de hele set van miniformaat is (denk aan 47 labs). Helaas was het laag wat aan de rommelige kant. Dit laatste wordt waarschijnlijk veroorzaakt door de afstemming van de luidspreker. De spukllen van CD design kenmerken zich door een signaalpad door zo weinig mogelijk onderdelen. Vanaf de DAC staan er slechts 4 transistoren in het signaalpad tot aan de luidspreker. Ook is er extreem veel aandacht aan reductie van jitter geschonken. De speler wordt gestuurd door één clock. Bovendien zijn er geen trillingen die de jitter kunnen beinvloeden. Kwa bedieningsgemak zag het er ook prima uit. Via een PC en smartfoon is het geheel op afstand te d bedienen. De speler kent alleen 16 Bits 44 kHz. Kwa prijzen valt het ook alles mee. Link to comment Share on other sites More sharing options...
rbh Posted 22 februari 2013 Report Share Posted 22 februari 2013 Leuk Hans! Waar te beluisteren? En SD Is de enige ingang? Geen USB. Link to comment Share on other sites More sharing options...
WanFie Posted 23 februari 2013 Author Report Share Posted 23 februari 2013 Alleen bij EC designs. De vormgeving is bij de laatste apparaten een stuk moderner geworden. Alleen USB voor de communicatie met de PC. Link to comment Share on other sites More sharing options...
Karma Posted 24 februari 2013 Report Share Posted 24 februari 2013 Ik begrijp dat je de eigen CD's via een "image" op deze speler kunt krijgen. Heeft het nu nog nadelen dat je de peecee gebruikt als "uitleesapparaat" om bestanden op deze speler te krijgen? Link to comment Share on other sites More sharing options...
WanFie Posted 24 februari 2013 Author Report Share Posted 24 februari 2013 Een CD rip je m.b.v. een PC naar een SD kaartje m.b.v. een ripper die de bestanden netjes geordent wegschrijft. Daarna het kaartje is de player en klaar is kees. De PC vind op de usb ingang het nummer van de SD kaart en zoekt de gegevens er bij. De USB aansluiting schijnt kompleet ontkoppelt te zijn. Met een smartphone, kun je de PC overnemen en de SD player dus ook bedienen. Link to comment Share on other sites More sharing options...
Karma Posted 24 februari 2013 Report Share Posted 24 februari 2013 Wat ik bedoelde was dat je vroeger allerlei fantastische loopwerken had zoals die het VRDS systeem van TEAC, of de CDM serie van Philips. Enorm robuust ontworpen systemen waaraan de nodige kwaliteiten werden toegeschreven. Tegenwoordig worden allerlei simpele platsic systeempjes gebruikt voor het uitlezen. Gaat dit ten koste van de kwaliteit? Link to comment Share on other sites More sharing options...
WanFie Posted 24 februari 2013 Author Report Share Posted 24 februari 2013 Het lezen van een CD in de PC gaat anders dan in een CD speler. De PC gaat n.l.veel sneller en is bit perfect. Dat plastic loopwerkje doet daar weinig aan af. Die zware loopwerken waren er vooral om trillingen in de kast en electronica te vermijden. Met z'n SD player heb je helemaal geen trillingen. Link to comment Share on other sites More sharing options...
WanFie Posted 24 februari 2013 Author Report Share Posted 24 februari 2013 Hier nog een plaatje van hoe het ding er tegenwoordig uit ziet. Link to comment Share on other sites More sharing options...
carl Posted 24 februari 2013 Report Share Posted 24 februari 2013 Wil je hem erbij kopen Hans of ipv Link to comment Share on other sites More sharing options...
WanFie Posted 24 februari 2013 Author Report Share Posted 24 februari 2013 Kopen...??? Nee, maar ik vond het wel een leuk ding om te laten zien. En het klonk nog eens goed ook. Link to comment Share on other sites More sharing options...
Guest Posted 24 februari 2013 Report Share Posted 24 februari 2013 Hansje, je gaat mij toch niet vertellen dat de PC beter is dan de cd speler. PS wollie heeft gewoon een sony erricson experia 8 als streamer en het doet het goed ook. Link to comment Share on other sites More sharing options...
WanFie Posted 24 februari 2013 Author Report Share Posted 24 februari 2013 Wolleke... ook niet slechter... En soms... heeel soms... denk ik dat de PC inderdaad beter is. Link to comment Share on other sites More sharing options...
