goodtube Posted 9 januari 2016 Report Share Posted 9 januari 2016 Maar men vond het dus rommel tenzij eigenhandig verbeterd. Link to comment Share on other sites More sharing options...
spido Posted 10 januari 2016 Report Share Posted 10 januari 2016 (edited) Maar men vond het dus rommel tenzij eigenhandig verbeterd. Beste Goodtube, Je lijkt steeds beter te worden in het trekken van voorbarige conclusies. DescriptionThe ERA 444 has truly earned its share of praise. It embodies the principal technical advances which have given ERA its international reputation. These features include the world's slowest-running synchronous turntable motor giving absolutely constant speed; ERA-patented Flexiprene belt drive; Silent Bloc mounting, another ERA original; pick-up arm incorporating the new ERA Frictionless Pivot — a unique development; anti-skating bias compensation. smoke-tinted Plexiglass cover. The turntable assembly is mounted in an attractive base, with wooden sides. The overall effect is elegant and restrained. It's excellent performance-to-price ratio ensures that the ERA 444 is not only unrivalled in its class; it also compares very favourably with units of far higher price. Motor: 48-pole, synchronous Speeds: 33 and 45 rpm Drive method: Flexiprene belt, precision-machined to 2 mills; single step-down gear Rumble: 73 dB (DIN ) Platter: metal throughout; balanced 12in dia (30 cm), 2,65 lb (1,2 Kg) Dimensions: 16 1/8 x 5 1/8 x 12 1/4 in (410 x 130 x 310 mm) Weight: 18 lb ( 8 kg ) http://www.vinylengine.com/library/era/444.shtml Edited 10 januari 2016 by spido Link to comment Share on other sites More sharing options...
Sodejuu Posted 10 januari 2016 Report Share Posted 10 januari 2016 Hoe kom je er bij dat hij 't met jou eens is? Hij is het vermoedelijk alleen maar (compulsief) òneens met mij! Zeg Sheldon, hoe kom je erbij om te denken dat de hele wereld om jou draait ? Link to comment Share on other sites More sharing options...
Members Arden Posted 10 januari 2016 Members Report Share Posted 10 januari 2016 Tja, ik moet Spido ook gelijk geven, ik heb echte hele leuke dingen gehoord uit ERA's die ik voor kennissen moest opbouwen. Echt niks mis mee. Tuurlijk, beter kan altijd, maar slecht kan ik het echt niet noemen. Link to comment Share on other sites More sharing options...
Sodejuu Posted 10 januari 2016 Report Share Posted 10 januari 2016 Ik heb er hier een aantal gehad, maar geen enkele die af fabriek gewoon goed was (het ergste zijn die neopreen "veren"). Je moet er heel wat aan doen om ze goed te krijgen. Maar ondanks hun waardeloze constructies, komt er wel muziek uit. Dat kun je van een Crosley of Ion niet beweren. Link to comment Share on other sites More sharing options...
Members Arden Posted 10 januari 2016 Members Report Share Posted 10 januari 2016 [...] Je moet er heel wat aan doen om ze goed te krijgen. Maar ondanks hun waardeloze constructies, komt er wel muziek uit. Dat kun je van een Crosley of Ion niet beweren. [...] Da's precies wat ik bedoel, er komt uiteindelijk echt wel muziek uit! Dat kan ik van een aantal moderne ''gadgets'' inderdaad niet zeggen! Link to comment Share on other sites More sharing options...
Duck-Twacy Posted 10 januari 2016 Author Report Share Posted 10 januari 2016 Zeg Sheldon, hoe kom je erbij om te denken dat de hele wereld om jou draait ? page 4 of the high-end forum agreement Link to comment Share on other sites More sharing options...
spido Posted 12 januari 2016 Report Share Posted 12 januari 2016 Zeg Sheldon, hoe kom je erbij om te denken dat de hele wereld om jou draait ? Sheldon? Who the f*ck is Sheldon? Link to comment Share on other sites More sharing options...
Plaatjesdraaier Posted 12 januari 2016 Report Share Posted 12 januari 2016 Sheldon Lee Cooper, Ph.D., Sc.D, ken uw klassiekers! Link to comment Share on other sites More sharing options...
spido Posted 12 januari 2016 Report Share Posted 12 januari 2016 Spido kijkt niet naar kinderseries op TV. Jij kennelijk wèl? Link to comment Share on other sites More sharing options...
Plaatjesdraaier Posted 12 januari 2016 Report Share Posted 12 januari 2016 Dit valt onder "algemene ontwikkeling", maar wereldvreemde mensen hebben ook hun rechten! Link to comment Share on other sites More sharing options...
