Duck-Twacy Posted 28 oktober 2023 Report Share Posted 28 oktober 2023 Grappig intro filmpje Link to comment Share on other sites More sharing options...
Seed7 Posted 29 oktober 2023 Author Report Share Posted 29 oktober 2023 Link to comment Share on other sites More sharing options...
Vinyl_Fuchs Posted 29 oktober 2023 Report Share Posted 29 oktober 2023 Link to comment Share on other sites More sharing options...
Seed7 Posted 30 oktober 2023 Author Report Share Posted 30 oktober 2023 Link to comment Share on other sites More sharing options...
Seed7 Posted 31 oktober 2023 Author Report Share Posted 31 oktober 2023 Link to comment Share on other sites More sharing options...
Seed7 Posted 1 november 2023 Author Report Share Posted 1 november 2023 Link to comment Share on other sites More sharing options...
Tubejack Posted 1 november 2023 Report Share Posted 1 november 2023 De dubbel LP Supertramp Paris. Link to comment Share on other sites More sharing options...
Seed7 Posted 2 november 2023 Author Report Share Posted 2 november 2023 Morgen komt de nieuwe uit, Link to comment Share on other sites More sharing options...
edwin16 Posted 2 november 2023 Report Share Posted 2 november 2023 Alvast een beetje voorbereiden op wat vanavond komen gaat in het Muziekgebouw in Eindhoven... Link to comment Share on other sites More sharing options...
WanFie Posted 2 november 2023 Report Share Posted 2 november 2023 Veel plezier Edwin, daar kun je misschien nog iets van leren... Link to comment Share on other sites More sharing options...
Roots Posted 2 november 2023 Report Share Posted 2 november 2023 Link to comment Share on other sites More sharing options...
Seed7 Posted 3 november 2023 Author Report Share Posted 3 november 2023 Link to comment Share on other sites More sharing options...
Seed7 Posted 4 november 2023 Author Report Share Posted 4 november 2023 (edited) Remasterrrr.............. Wat hebben zij bij die tweede gedaan? Edited 4 november 2023 by Seed7 Link to comment Share on other sites More sharing options...
Bloom Posted 4 november 2023 Report Share Posted 4 november 2023 Origineel DR11, remaster DR10. Remaster heeft duidelijke vervorming, maar de stem zit wel in het midden daar waar ze in het origineel meer uit links komt. Niettemin vind ik het origineel beter klinken. Link to comment Share on other sites More sharing options...
Seed7 Posted 4 november 2023 Author Report Share Posted 4 november 2023 53 minutes ago, Bloom said: Origineel DR11, remaster DR10. Remaster heeft duidelijke vervorming, maar de stem zit wel in het midden daar waar ze in het origineel meer uit links komt. Niettemin vind ik het origineel beter klinken. Helaas weet ik niet of het origineel origineel is. Ik kan het niet met mijn exemplaar vergelijken en dan nog weet ik niet of het de zelfde opname is. Wat ik bij de twee hoor is "phasing", een beetje alsof er door een buis gezongen wordt. De stem is kleiner en lijkt verder weg. Het klinkt m.i. afschuwelijk. Ik zal eens zoeken of er een kopie van de versie die ik hier heb te vinden is. Link to comment Share on other sites More sharing options...
Seed7 Posted 4 november 2023 Author Report Share Posted 4 november 2023 Dit is wat ik heb, een Franse verzamelaar EP https://www.discogs.com/master/846282-Paul-Robeson-Récital Dit is de muziek van die EP, Track 9 is Loch Lomond Link to comment Share on other sites More sharing options...
René N. Posted 4 november 2023 Report Share Posted 4 november 2023 5 hours ago, Seed7 said: Dit is wat ik heb, een Franse verzamelaar EP https://www.discogs.com/master/846282-Paul-Robeson-Récital Dit is de muziek van die EP, Track 9 is Loch Lomond Deze derde klinkt m.i. het meest "natuurlijk". Bij de eerste hangt de stem inderdaad wat meer naar links en lijkt het in een kerk of zo opgenomen te zijn. En, na 20 seconden, begint de stem van links naar rechts en weer terug te schieten, en dat gaat even zo door. De tweede is niet om aan te horen, inderdaad achterin ergens, en met een hele holle stem. Bij de derde is dat allemaal wel goed, ook heel iets links van het midden trouwens. Grappig om de verschillen zo duidelijk te horen... Link to comment Share on other sites More sharing options...
Bloom Posted 4 november 2023 Report Share Posted 4 november 2023 Het probleem met Paul Robesen is dat de bulk van diens werk nog voor de tweede wereldoorlog opgenomen werd, met als gevolg vaak in mono en met een kwaliteit die we nu als belabberd zouden omschrijven. En zeker in de VS werd nauwelijks aandacht besteed aan de geluidskwaliteit voor zwarte zangers of artiesten. Het is dus zéér moeilijk een goede opname van Paul Robesen te vinden. De "geremasterede" opnames die je tegenwoordig nog al eens tegenkomt bieden zelden soelaas: als het origineel niet goed is, valt er weinig meer van te maken. En als je het teveel met de computer gaat bewerken, klinkt het steeds onnatuurlijker. Als je van diepe basstemmen bij mannen houdt, zou ik eens op YT zoeken naar Geoff Castellucci. Bijvoorbeeld Link to comment Share on other sites More sharing options...
