Ruud Posted 18 augustus 2003 Report Share Posted 18 augustus 2003 Een Nederlander geeft een bezoekende Belg een rondleiding door zijn huis, "Kijk dit is mijn slaapkamer, hier de keuken, de badkamer en hier mijn muziekkamer" Amai, maar deze kamer is geheel leeg, vanwaar dan muziekkamer"? vraagt de Belg hem. "Ja, dat zie je goed hoor", antwoordt de Nederlander. " Maar hier hoor je de radio van de buren het beste. Link to comment Share on other sites More sharing options...
Sodejuu Posted 18 augustus 2003 Report Share Posted 18 augustus 2003 After every flight, pilots fill out a form called a gripe sheet, which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The mechanics read and correct the problem, and then respond in writing on the lower half of the form what remedial action was taken, and the pilot reviews the gripe sheets before the next flight. Never let it be said that ground crews and engineers lack a sense of humor. Here are some actual logged maintenance complaints and problems as submitted by Qantas pilots and the solution recorded by maintenance engineers. By the way, Qantas is the only major airline that has never had an accident. (P = The problem logged by the pilot.) (S = The solution and action taken by the engineers.) P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit. S: Something tightened in cockpit. P: Dead bugs on windshield. S: Live bugs on back-order. P: Autopilot in altitude-hold mode produces a 200 feet per minute descent. S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That's what they're there for. P: IFF inoperative. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspect you're right. P: Number 3 engine missing. S: Engine found on right wing after brief search. P: Aircraft handles funny. S: Aircraft warned to straighten up, fly right, and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget. Link to comment Share on other sites More sharing options...
The Koosjer connection Posted 18 augustus 2003 Report Share Posted 18 augustus 2003 Nou moeten jullie weten,of niet,dat ik net een periode van een week[verplichte] rouw heb afgesloten met een wederbezoek aan de begraafplaats in zo'n 40 graden. En dus na de broodnodige douche,en een kouwe rakker,en het lezen van deze verhalen,weet je gewoon dat de aardkloot [gelukkig] gewoon door draait Thanx, --Hans. Link to comment Share on other sites More sharing options...
John Posted 20 september 2003 Report Share Posted 20 september 2003 Rijden 4 belgen over de wallen en zien ze opeens een dame van lichte zeden op de straathoek staan ........... de chauffeur vraagt aan de dame ... hallo madame wat kost het bij u ? de dame antwoord : Link to comment Share on other sites More sharing options...
depeter Posted 20 september 2003 Report Share Posted 20 september 2003 Zitten twee belgen opgesloten in een grot, roept de eene belg HELP, zegt de andere dat helpt niet we moeten samen roepen "SAMEN". Link to comment Share on other sites More sharing options...
Sodejuu Posted 20 september 2003 Report Share Posted 20 september 2003 In een inrichting voor prettig gestoorde mensen wil er eentje uitbreken. Hij zegt tegen een medegedeponeerde dat hij as maandagmiddag zal uitbreken en wil vluchten door over het hek te springen. Hij gaat gelijk in training. Allereerst springt hij met veel verachting over een splinter, vervolgens een lucifer en daarna een schrootje. Na enkele dagen training en het opvoeren van de moeilijkheidsgraad denkt hij klaar te zijn. Hij verteld het aan de medegedeponeerde dat de dag is aangebroken. Gelijk na het middageten maakt hij er zich van tussen. Tegen de avond komt hij moe en teleurgesteld terug. "Zo,", vraagt de medegedeponeerde: "alweer terug???". "Ja!" zegt de uitbreker: "Het hek stond open!?!" Link to comment Share on other sites More sharing options...
Maurice Posted 22 september 2003 Report Share Posted 22 september 2003 Een treinverhaal... Een Nederlander, een Duitser, een bloedmooie meid met een kort rokje en een paar beste tieten en een non zitten in een treincoupe. Op een gegeven moment rijdt de trein een tunnel in, het licht werkt niet dus het is pikkedonker. Dan klinkt er een harde klap en als de trein de tunnel weer uitkomt zit de Duitser pijnlijk in z'n gezicht te wrijven. "Net goed", denkt de non, "die Duitser heeft natuurlijk geprobeerd die meid te pakken en die wilde dat niet en heeft hem geslagen!" "Net goed", denkt de mooie meid, "die Duitser heeft natuurlijk mij willen pakken in het donker, heeft per ongeluk die non gepakt, die wilde dat niet en heeft hem geslagen!" "Scheisse", denkt die Duitser, "die Nederlander heeft natuurlijk geprobeerd die mooie meid te pakken, heeft per ongeluk die non gepakt, die wilde dat niet en heeft hem geprobeerd te slaan Die Nederlander realiseerde zich dat en heeft gebukt, waardoor ik de klap heb gekregen!" En de Nederlander denkt: "In de volgende tunnel sla ik die Duitser gewoon weer op z'n smoel...!" Met dank aan de Duitser bij ons op de opleiding, die deze verspreidde over de mailinglist. Link to comment Share on other sites More sharing options...
Wijx Posted 22 september 2003 Report Share Posted 22 september 2003 wat is het verschil tussen een stoephoer en een straathoer? 10 cm Link to comment Share on other sites More sharing options...
Geerdie Posted 22 september 2003 Report Share Posted 22 september 2003 Er lopen 2 blondies te wandelen door het mijnengebied van Limburg. Zegt de Link to comment Share on other sites More sharing options...
Arnie Posted 22 september 2003 Report Share Posted 22 september 2003 een man loopt over de wallen, en stopt even voor een met rood licht gesierde ruit.... hij tikt tegen de ruit aan en vraagt aan de schaars geklede dame "wat kost dat??" "35 euro!!" zegt de dame.. zegt de man "goh... da's niet duur voor dubbel glas!" Link to comment Share on other sites More sharing options...
Hans van Liempd Posted 22 september 2003 Report Share Posted 22 september 2003 Lopen er twee nullen door de woestijn... Komen ze een acht tegen.... Zegt de ene nul tegen de andere.... poe poe, en dat, met dat weer.... Link to comment Share on other sites More sharing options...
Henrie Posted 22 september 2003 Report Share Posted 22 september 2003 "There are only 10 types of people. Those who understand binairy and those who don't" Link to comment Share on other sites More sharing options...
cgm Posted 22 september 2003 Report Share Posted 22 september 2003 Geplaatst door Henrie:"There are only 10 types of people. Those who understand binairy and those who don't" There's no place like 127.0.0.1 Link to comment Share on other sites More sharing options...
