Cyrus 2 schema
Sebastiaan de vries
Cyrus 2 is lastig.
Cyrus 1 is een makkie
http://www.tcaas.btinternet.co.uk/cyrus1pwr.gif
van http://www.tcaas.btinternet.co.uk/index-4.htm
misschien icm deze quote http://www.diyaudio.com/forums/showthread....4948#post404948
The boards for the Cyrus 1 and 2 were the same. The only differences between the two, so far as I am aware, is that the 2 had an improved phono stage, higher supply rail voltage for the power amp section and larger output transistors (parallel pairs of the same output transistor were used in earlier models).
misschien weten ze hier meer
http://www.rdh.34sp.com/forums/
